2000 Outlander idles to low.
Old May 29, 2015 | 04:39 PM
Danny-'s Avatar
Default 2000 Outlander idles to low.
I got a 2000 outlander xls 112xxx miles, that has started some idling problems at stop lights. Drives fine, the powers still there, but when you stop it starts bouncing around from 800 rpms to 400-500 and wants to die. Checked for codes, said cylinder 4 had misfired. Changed spark plugs and it fixed that issue but it's still idling bad and getting worse. The car is new to me and I haven't changed much on it other then oil+filter and ATF. so I was thinking maybe a clogged fuel filter?
Thought I'd see what opinions you guys had, maybe sensor I don't know about? Or if anyone else has had this issue.
Thanks for the time and any impute.
Old Feb 17, 2016 | 10:21 PM
WHITEOUT2010's Avatar
Battery. Check voltage. Lower than 12v, replace.
Jayc71
13
May 19, 2022 02:23 AM
Galanthighspeeder
Apr 30, 2012 05:01 PM
EclipseBabe29
Feb 5, 2006 03:05 PM
dcs92talontsi
1st Generation
Dec 28, 2005 03:39 PM
96galantS
Jun 2, 2005 04:55 PM
