TSi no power and idles rough
Old Dec 27, 2005 | 04:22 PM
dcs92talontsi's Avatar
Default TSi no power and idles rough
I have a 92 TSi. A few weeks ago I noticed after driving the car for a while and turning it off, when I went to restart it the car would idle rough and/or die. It would restart and I would rev it to 3 or 4000 rpm and hold it for 10 sec and let it return to idle then it was fine. It has progressively occured more often. The last couple of days when I would go to full throttle the car would lay down, but part throttle it ran fine. Now it won't clear out with revving it and the power is non-existent. The car is completely stock, boost gauge reads normal boost. I checked all tubing from mass air to throttle body, everything's tight. Checked plugs, cylinders 1 and 4 appear to have a slight fuel smell, 2 and 3 don't have that. I did notice raw fuel smell coming out the exhaust tip. TPS was normal, coil appears to be normal based on resistance testing. Any ideas or suggestions would be appreciated.
TIA
Old Dec 27, 2005 | 06:46 PM
Sanguinius's Avatar
Default RE: TSi no power and idles rough
I'd say change plugs and wires first. You say you checked the plugs and could smell gas on 2 but did you check them for spark? Also check your throttle body foir carbon buildup.
Old Dec 28, 2005 | 03:11 AM
DSMTalonAWD51's Avatar
i had the same problem. check yous isc motor, and your egr valve. do you have a check engine light?
for a temporary fix you can adjust your BISS screw on your throttlebody. just try turning it counterclockwise half a turn to start.
Old Dec 28, 2005 | 03:39 PM
Sanguinius's Avatar
Carefull adjusting that screw. If that's not the true problem then you're not going to be doing anything but prolonging the discovery of what's actually wrong.
Galanthighspeeder
Apr 30, 2012 05:01 PM
neurocrash
Apr 20, 2008 08:04 PM
00monty
Oct 25, 2006 02:24 PM
EclipseBabe29
Feb 5, 2006 03:05 PM
96galantS
Jun 2, 2005 04:55 PM
