Montero idles rough
Old Oct 25, 2006 | 12:13 AM
00monty's Avatar
Default Montero idles rough
Posted this on the Montero forum and got some good input, just trying to get some more opinions. Battery hooked up backwards-(Don't ask!)- Changed radio fuse and Alt 100 amp main fuse that were blown. Car now idles fine cold, gets real rough after warm. If I baby throttle past idle, it will rev fine. ECM not giving any codes, even with sensors disconnected. IAC, throttle position and coolant temp sensor ohm out fine. Dealer says new ecm needed, and along with that, immobilizer ECM and ignition key reformat. Need more opinions before I fork out almost two grand! It's a 2000, 3.0 liter, LS. Got two different suggestions for fuel pump control module.
Old Oct 25, 2006 | 12:20 AM
Default RE: Montero idles rough
Double posting will not get you an answer any faster
Old Oct 25, 2006 | 02:24 PM
00monty's Avatar
I'll stay in Montero forum, thanks
Galanthighspeeder
Apr 30, 2012 05:01 PM
phyukewe
Jan 24, 2007 06:53 PM
EclipseBabe29
Feb 5, 2006 03:05 PM
dcs92talontsi
1st Generation
Dec 28, 2005 03:39 PM
96galantS
Jun 2, 2005 04:55 PM
