I've just removed mine by removing the securing nut ,starlock washer, and steel washer ,I then had to punch out the spindle as it had rust jacked inside the body, , try not to damage the starlock washer to much as you may need to reuse it unless you have replacements. .
Wow, thanks for letting me know. I was afraid to touch this part just because i have no replacement available for this. its too expensive here.
Could you pls share some pics of the same, that I could get a better idea.
