4g93 gdi problem
Old Mar 2, 2017 | 09:49 PM
ryanrod's Avatar
Default 4g93 gdi problem
Hi all, im new to this forum and I have some issues with my lancer.
any help would be much appreciated. car has a 1.8l 4g93t gdi engine. two days ago whilst driving, the engine check light came on and car started stalling. i turned the ignition off and then on again and the problem stopped. it was then taken to my mechanic where the engine was inspected, which showed an oil leak coming from the camshaft cap gasket and dripping onto the spark plugs. the leaked was repaired but the engine stalling persisted. the spark plugs and coil packs were replaced and engine was turned on, but shut down after 5 seconds. the engine was turned on again with air flow sensor removed and worked perfectly fine. the sensor was re-connected, engine turned on with no luck. any suggestions?
Old Oct 11, 2018 | 12:20 PM
Kriston63T's Avatar
Adjust your TPS sensor. Shift it slightly to the left and try starting again.
1590gilbert
Feb 24, 2023 03:43 PM
Nirkel
Apr 11, 2014 11:36 AM
Harv
Feb 24, 2013 08:36 AM
smokey mcpott
Mar 10, 2012 03:34 PM
Adelton NZ
Aug 10, 2010 10:07 PM
