7 different system service errors came on after checking fuses on Pajero sport
hi all
i have a 2019 Mitsubishi Pajero sport (in Aus) and my aircon has been playing up so I checked the fuses. After checking the fuses and switching the car back on I was treated with all the error messages pictured below.
i only removed 2 fuses marked AC and put them back, and also accidentally the safety horn fuse which I had put back in the wrong spot (which was blank) but rectified. All are 20amp fuses I removed so none went back in as wrong amp. The battery isn’t perfect and has some corrosion around the grounding wire and positive terminal but I cleaned that and it hasn’t been an issue prior to make removing the fuses.
i can start the car but due to the errors I cannot even reverse the car out of my driveway.
so what could be going on here? Is it just a simple case of needing a scan tool to clear the errors or would they come back? Can these service errors be cleared with a scan tool easily? Thanks
Reason: Updated info and title
