95 ECLIPSE ECU
Old Oct 14, 2005 | 11:56 PM
badlarry's Avatar
Default 95 ECLIPSE ECU
Hey guys I'm buying a 95 eclipse and it needs an ECU swap. how intensive is this? and if it's over my head what does an install usually run. I'm really only a weekend mechanic.
Thanks
Old Oct 15, 2005 | 06:09 PM
FireDoc's Avatar
Default RE: 95 ECLIPSE ECU
Disconnect battery, Unscrew plastic panel(I only had 1G's) whichever that may be, unbolt ecu, unplug, repeat steps in reverse. Thats it from the mechanical side. Try to leave your battery diconnected for 20 minutes or so unless someone here knows of any other quirks in the 2G's?
Old Oct 15, 2005 | 07:52 PM
Lil red's Avatar
Hope you know the radio code when you unplug the battery... Or hope you have a aftermarket radio. Shouldnt be to hard to get out should be harder to find it in the first place.
Old Oct 16, 2005 | 09:30 AM
wicked_outlander's Avatar
ORIGINAL: FireDoc
good to go...
Old Oct 17, 2005 | 12:16 AM
DSMTalonAWD51's Avatar
its easy but the question how do you kno you need a new ecu?
JeremyMinton
Jun 6, 2009 02:53 PM
nyc95gst
Jan 18, 2008 01:25 PM
poiz
May 9, 2006 08:14 PM
DR_NO
Feb 15, 2005 12:04 AM
nikozai
Jan 29, 2005 03:44 PM
