95 eclipse gs and water dont mix
Old Sep 22, 2004 | 03:27 PM
Ziggy's Avatar
Default 95 eclipse gs and water dont mix
Hey guys. I'm looking for a little help on my engine. It's a 2.0 DOHC 5 speed. I took in water thought my cold air intake (I'm kicking myself for not having a bypass) and my engine pretty much died soon after. So now I'm inthe market for another engine. I know my rings are gone along with other things. So here is where the advice is needed. should I try to find an already rebuilt one or shoulf i try to rebuild the one I already have? And if I should rebuilt the one I have, where should I go for parts? I don't want anything top of the line, but reasonable performance wise. also what am I looking at as far as cost? I'm really low on cash cuz I just bought this eclipse in late august. Someone please help me out cuz I'm dying here.
Old Sep 22, 2004 | 04:48 PM
SpyderGS's Avatar
Default RE: 95 eclipse gs and water dont mix
ahh here comes the big question, do you want to turbocharge your car anytime soon? If not, you can always go stroker for real cheap!!! I mean really really cheap! Not like $5 cheap, but under $800 with high comp pistons and rings, and rods. It would be cool!!
Old Sep 22, 2004 | 08:08 PM
Ziggy's Avatar
man under 800 sounds like a blessing! where would be a good start as far as where to look for one of those? also, how much power do u think I can get out of a stroker? my friends and I are starting a racing team and i have a 300zx twin turbo to compete with. I'm not trying to be the runt of the group u know what I mean?
Old Sep 24, 2004 | 12:12 PM
SpyderGS's Avatar
The bad news is, instead of spending money, you'll be spending time. Chrysler made a ton of 2.4liter 420a engines, they're all in dodge caravan, a few cloud cars, and you may notice it's in the neon srt-4 now. You can go to just about any junk yard and find a dodge caravan and take the block out of it with the help of some buddies. Now, you'll have to take the block out and get it to a machine shop to have it checked and cleaned up. Get some Arias pistons for the 2.4liter 420a and have the shop assemble everything for you. Then you can either have the shop install the block, or you can do it yourself. Make sure to keep the cylinder head from your car. Seeing as the engine hydrolocked, are any of the valves bent? If they are you can always upgrade to better springs and SS valves. If you get new gear in the head, the price may jump to $1000, so be aware. The most expensive thing in the swap is the shop costs. The pistons(with rings) go for about $300-$350, and the block may cost around $20-$100 depending on where you go. The reason that the block is so cheap is because there are so many of them and they are not really in demand. Now, this engine will have broad torque curve, and is capable of producing 200hp crank depending on compression ratio and cams. You can gain some extra hp by getting custom cams OR using cams from a Neon R/T or ACR. However, it won't beat a modified 300zxtt. Maybe in the 1/8 mile, but probably not the quarter. If you're wanting to take on that, you may have to tubocharge your car. You won't be a runt either, you'll be able to beat a stock eclipse gst, so you'll be in between. But if you want extreme power, count on spending about $1700 for an engine rebuild and turbo kit. Of course you can do stroker and turbo and make something similar to an SRT-4....just better looking
JohnnyK
Jun 2, 2011 01:10 PM
shunter
Nov 25, 2010 09:53 AM
Injen2nr
Apr 3, 2008 07:15 PM
tx2u
Jan 6, 2008 12:59 PM
EMonz57
May 6, 2006 08:36 PM
