95 Mits Eclipse Loud Pop/stopped running
Old Oct 19, 2008 | 12:58 PM
twarrior's Avatar
Default 95 Mits Eclipse Loud Pop/stopped running
I have a 1995 Mitsubishi Eclipse GT. While driving down the road there was a loud bang/pop then the motor died. I coasted into a parking lot and tried to start the car. The starter just spins freely and doesn't engage the flywheel. Would a hosed starter cause the engine to quit running? I tried to push start the car and guess I wasn't strong enough. Is there a way to bypass the starter to get the car running? Could there be other issues??
Thanks
John
Old Oct 19, 2008 | 01:11 PM
Default RE: 95 Mits Eclipse Loud Pop/stopped running
Is the car turbo or non turbo?
Is it a manual trans or auto?
Old Oct 19, 2008 | 01:25 PM
twarrior's Avatar
It's a Turbo and a 5 speed.
Thanks,
Old Oct 19, 2008 | 03:20 PM
dsm1990gsx's Avatar
How many miles are on it? Have you ever changed the timing belt?
Old Oct 19, 2008 | 03:44 PM
twarrior's Avatar
I had a complete rebuild port/polish all inards including timing belt, seals,gaskets, crank/cam sensors..etc. I suppose it could still be the timing belt though. Not sure I want to try and push start it if something is broken inside... could cause more damage. Guess I'll have to call the mechanic and get it towed/fixed. I was hoping there would be some simple ways to test what could be wrong besides the started being smoked.
Thanks,
John
Old Oct 19, 2008 | 05:36 PM
Pull off the timing cover and check that out. Sounds too typical.
LOWRIDER60
Apr 11, 2008 08:41 PM
dandeering
Nov 23, 2007 05:35 PM
paintballproam
May 22, 2007 02:17 PM
BoostNightRanger
1st Generation
Feb 26, 2007 05:48 PM
spyder4g63t
Oct 18, 2006 08:20 PM
