98 Eclipse GST boost?
Old Jun 23, 2005 | 04:23 PM
garod82's Avatar
Default 98 Eclipse GST boost?
I just bought a 98 eclipse gst and i want to know what is a safe boost increase with everything stock except i'm going to put on the greddy front mount intercooler. So my question is: what is the stock boost set at and how much can i increase the boost on the stock turbo and stock motor?
Thanks.
Old Jun 27, 2005 | 09:04 PM
bjsstang05's Avatar
Default RE: 98 Eclipse GST boost?
hmm thats a good question. im not sure. whats the stock boost #? you got a boost gauge? i think 12lbs is safe for stock if you going with the front mount intercooler. i read in a magazine some where that you can increase boost. but ill have to read it again and get back to you.
brandon PS hope your still on :P LOL no ones replied to this question
Old Jun 28, 2005 | 09:15 PM
bjsstang05's Avatar
ORIGINAL: bjsstang05
ok here it is the guys in "import tuner" magazine has a 1991 eclipse and it was turbocharged. he used a fish pump manifolid its made of polymer which by the way nasa uses. so no worries on failure. heres how it works... cut the vacuum line and place the manifold in the line with the two sides. ensure that the manifold valves are in the closed position. you should be able to blow through one side of the valve with air only comming through one side, the opposite end of the valve. and not the rest of the ports. to increase boost pressure, open one of the valves unit the vehicle hits the desired boost level. if more boost is needed simply open more valves.
brandon
Old Jul 4, 2005 | 09:15 PM
DSMTalonAWD51's Avatar
a buy a boost gauge so u can see what you are doing
b buy a boost controller so u can adjust it
c buy a bov so you can increase your boost without it leaking away
16psi is fine, stock is around 11-12
cheeks97gst
Jan 16, 2012 08:23 PM
anko_kun
Dec 24, 2006 07:48 PM
baker_sk8er37
Oct 14, 2006 10:38 PM
xplisit_bg
Dec 21, 2005 09:05 PM
98GstSpyder
Jun 10, 2004 11:11 AM
