98 talon poss bad cam sensor
Old Sep 12, 2007 | 11:07 AM
ck76's Avatar
Default 98 talon poss bad cam sensor
my brother in law has a 98 talon 420a motor. he was driving it and heard a loud *** noise that he thought was a tire blowing out. the car died,,,, upon inspection the brand new p.s. belt was broke and wrapped aroung the crank. we replaced it nut the car had no spark. nothing from the coil. so i replaced the sensor cam sensor & still nothing,, but here is the crazy part. if you unhook the sensor the car will start, but not running right..... if you unbolt the sensor, hook it up and hold it away from the motor it will run. but when you get it close to the spot where it bolts up the car will start to sputter & then die... please help with this...thanks guys.
Old Sep 12, 2007 | 03:47 PM
ck76's Avatar
Default RE: 98 talon poss bad cam sensor
nevermind i got it fixed, timing belt jumped 2 teeth!!!!!!!!!!!!
killzzz1
Jul 22, 2006 06:40 PM
janine
Apr 2, 2006 01:33 AM
Sallback
Nov 28, 2005 01:55 AM
Black98
Apr 16, 2005 07:23 PM
myspyder
Jun 8, 2004 09:14 PM
