99 Mirage 1.5 stalls at complete stops
Old Nov 15, 2006 | 10:04 PM
Monkton's Avatar
Default 99 Mirage 1.5 stalls at complete stops
Well this just started today. My car has always kind of idled off, but never to the point where it would stall. Today it started where I would pull up a stop sign or redlight and when I completely stop the car stalls on me. I have the clutch all the way down and it's almost instant when it happens. Sometimes I can see the lights on the dash start to come up but it doesn't, and very rarely it's fine. The only thing different from before is today I put a 600w Alpine amplifier in, but I even turned the CD player completely off and it still happened. Any suggestions? No SES light or anything like that at all.
Old Nov 16, 2006 | 10:44 AM
Default RE: 99 Mirage 1.5 stalls at complete stops
ussually idle problems attribute to a bad sensor, either the idle air control (IAC), or the throttle position sensor (TPS) but sincs you dont have a CEL i cant see either being the case or it would have thrown a code. What RPM does your car idle at normally, i mean when you say its always a little 'Off'. Does the idle kinda fluctuate? One easy thing to do is to clean the throttle body. Its a free thing to check anyway. Also i would check you battery terminals. Sometimes a bad terminal can do that, becuase it wont give the full juice. I know that one from experience. I had the car towed cuz it wouldnt stay idling without gas, and i come to find the negative was terribly corroded. So even if they dont appear too bad you might as well try that too since its only like 8-10 bucks for two terminals
Old Nov 16, 2006 | 11:11 PM
Monkton's Avatar
I wish I could tell you RPM but for some reason Mitsubishi thought it would be a great idea to have a manual without a tach lol Although I like it because I learned how to drive manual without one, so I can pretty much drive anything now. It didn't do it at all today so I have no idea what was going on yesterday...
licanstik
Aug 14, 2014 04:15 PM
johnnybowen
Dec 16, 2012 11:05 AM
fredij2004
Jun 2, 2009 02:57 PM
dongdong
Aug 29, 2005 11:12 PM
johnnybowen
May 29, 2005 06:13 PM
