Aftermarket BOV
its different on the 2G. There is a different mounting setup. Actually, im not sure how much you know about turbo bov setup, so forgive me if you know this. The bov is shortly before your throttle body. it is a cheap plastic cylinder with a rubber line running to the intake manifold... sensing pressure drop from behind TB to know when to vent. But mind you it is generally better to vent back into the intake as by venting to the atmosphere the computer gets confused. You are dumping air that the car has already accounted for out of the system and the stock computer has issues with that.
But with a good metal intake pipe and a K&N filter the bov venting back into the intake sounds pretty good.
