bad compression
Old May 17, 2009 | 04:43 PM
97mitsu_rs's Avatar
Default bad compression
ok so a buddy of mine just put a new engine in his eclipse. its a 420a and he did a compression check and theirs no compression in any cylinders. is their something he needs to do to get compression or is his head messed up? ive never rebuilt an engine so im not much help.
any help id appreciate it
Old May 20, 2009 | 08:26 PM
did you break it in?....who built the engine? Are these new internals and everything? More info on the engine
Old May 21, 2009 | 03:03 PM
97mitsu_rs's Avatar
stock internals stock everything. he put it all back together himself everything is torqued down fine. everything was previously used. 100k on new engine
Old May 21, 2009 | 04:20 PM
dsm1990gsx's Avatar
Is it timed properly?
Old May 21, 2009 | 08:01 PM
that would be my first thought is timing then
Old May 23, 2009 | 07:38 PM
97mitsu_rs's Avatar
its in time correctly the cam sensor is fine the crank sensor is fine and the ecu is fine...the only thing i can think of is that the valves are bent in the head
Old May 23, 2009 | 09:47 PM
dsm1990gsx's Avatar
Sounds like time to do a cylinder leak down to find out for sure.
nawgee
Oct 20, 2008 06:24 AM
wega
Sep 30, 2007 11:48 PM
agallardo
Oct 1, 2006 02:07 AM
TheMatt06
1st Generation
Jan 29, 2006 02:42 AM
vertstanggt
Jan 9, 2005 12:13 AM
