Brake Light on Outlander won't go off?
I did a search and did not find anything to address this.
We recently had out brakes checked and the Mitsubishi service people said they were fine.
The brake light is constantly on.
I tried pulling up the emergency brake and then putting it back down (kind of like a reset) and it didn't change anything - light is still on.
Any suggestions?
Thanks,
Johnny
Any suggestions?
Thanks,
Johnny
Well u have to do one at a time but disconnect the e-brake sensor if it stays on its not it and do the same thing to the float sensor under the hood. If the light goes out when you do that then thats your problem.
There could be a small chance if your abs module is shot it can keep the brake light on. Happen to once on a sable.
ORIGINAL: TheEngineer
its most likely your ebrake sensor, there is no such thing as a sensor that says your brake pads or rotors are bad, besides the pin.
mainelary
Jul 12, 2021 10:32 AM
serenabkhan
Nov 23, 2007 05:44 PM
