car has no heat
Old Oct 22, 2005 | 06:28 PM
ad37@verizon.net's Avatar
Default car has no heat
my 2002 galant is not putting out any heat. i have checked fuses, coolant level etc. it appears the heater control valve is not opening. the door opens as i have gone in the dash to verify it opens and closes. last year when i would switch the dash **** from cool to heat i would hear a buzzing sound on ocassion but it would throw heat. this time no noise no heat. i cannot find a schematic for the car. is the heater control valve operated by a relay and if so where is the relay and how could i check it with a meter? thanks
Old Oct 22, 2005 | 07:13 PM
Sanguinius's Avatar
Default RE: car has no heat
The easiest way to check a relay is to swap it with a similar relay. If you heard a buzzing it could be either the relay or the motor (If it's controlled by a motor). I'd suggest getting a chiltons or Haynes manual they should ave schematics for you.
Old Oct 23, 2005 | 03:08 AM
Joel_CA's Avatar
There are 2 blend doors visible from under the dash. One is to switch from fresh air to recirc air, the other is to switch from hot and cold. Have tried moving the **** on the dash while inspecting to see if the blend doors move? I just want to make sure your verifying the right blend door.
Joel, CA
curt6887
Feb 23, 2011 01:13 PM
TheEngineer
May 10, 2007 06:21 PM
ad37@verizon.net
Oct 24, 2005 06:58 PM
BigDawg
Dec 29, 2004 08:51 PM
Newbiedude
Jun 13, 2004 12:24 PM
