Check engine light
Old Mar 19, 2006 | 12:07 PM
gstTurbo2011's Avatar
Default Check engine light
Yea..my check engine light is on ..i think its because of the mods i've put on my car..is there away to reset my ecu to change that..thanks...
99 gst turbo
Old Mar 19, 2006 | 08:48 PM
dirtwagon's Avatar
Default RE: Check engine light
If your CEL is on due to your mods, it'll probably stay on with the mods. What did you modify? You can try to disconnect the ground from your battery for 45 mins-1hour and that should "reset" the computer. There may be a different way to do it, but I have a tinge of red on my neck so that's how I do it.
Old Mar 19, 2006 | 10:24 PM
ORIGINAL: dirtwagon
well if the computer is on because of mods thne you just forgot to plug something in. Check around. Or just go to autozone and have the code read. But if you just want to try and clear it then you just unplug the negetive terminal, but you don;t need to do it for an hour. A couple of minutes will do it.
Old Mar 20, 2006 | 10:37 PM
if my check engine light is on ..will i fail the emissions check?
Old Mar 20, 2006 | 11:27 PM
Sanguinius's Avatar
Depends on your state... VA doesn't care about the CEL but an airbag light will fail you in a heartbeat...
Old Mar 21, 2006 | 12:31 AM
ictponder's Avatar
Autozone FTW, then do what I did and tell everyone here what code you got.
Old Mar 21, 2006 | 03:09 AM
Sanguinius's Avatar
Yeah go to autozone get the code read write it down and then have them clear the code. Tell us what the code is and we'll tell you how to fix it.
Old Mar 21, 2006 | 09:29 AM
well since you live in boston, MA (sweet right in my back yard ) you will definetly fail emmissions so you need to get it fixed. My quess is it will just end up being somethign simple such as a sensor. But if you want to try and pass the emmissions without fixing it then unplug your battery for a couple of minutes in a parking lot near the inspection place. That will clear the code. Then hopefully it wont come back on when its getting done. Try it first on your own and see how long before it comes back on.
Old Mar 21, 2006 | 05:38 PM
slow420a's Avatar
If you have a 99 gst you can pass with out the problem fixed, in late 98 cars and newer they no longer stick the sniffer in the exaust they just hook the car up to a computer and read it like that. Chances are you have a rear o2 sensor code(thats if you removed the cayt) in that case pull up to a parking lot very close to the inspection startion, reset the ecu, and get the car inspected immediatly. It worked with my friends 2003 mazda speed protege.
Old Mar 22, 2006 | 12:33 PM
yup thats exactly what i was saying. It would have worked for my car, had it not failed the emmission test. Everything failed by double the state regs ooops
guyjg
Nov 13, 2021 03:27 PM
SpyderGST
Dec 27, 2014 06:50 PM
pgb205
Jun 4, 2009 10:40 PM
c577
Oct 16, 2007 12:03 AM
rkerner
Jul 22, 2005 01:04 PM
