Cylinder 2 Misfire Detected
Old Dec 16, 2020 | 07:37 AM
jssjr5591's Avatar
Default Cylinder 2 Misfire Detected
I have a 1997 Mirage 1.8 LS. About a week ago I barely made it home as the car began running rough. Came home and it ran fine next day. It had a code for Cylinder 2 Misfire Detected. The negative battery post was very corroded. I cleaned it up and it ran strong. I drove about 5 times maybe 20 miles total. Then yesterday it started same issue and same code.I am guessing it is spark plug related. I don't see any plugs at least in plain site. Also thought about bad fuel. Any ideas why problem is intermittant and possible fixes. Thank you. It has 209.000 miles.
Old Dec 16, 2020 | 02:29 PM
jssjr5591's Avatar
In between snow flakes, I checked car again. Put in a bottle of Lucas Oil Injection Cleaner not difference. Finally figured out where coil/s are located. The main coil makes a buzzing/grinding noise on ignition turn off now. The center coil pack is the one for cylinder 2. I am not sure if both are bad or just one. Also, how do they come off of the spark plugs? I don't want to mess things up. I think I can check the plugs although I don't have a plug wrench socket. Looks like parts are about $150. Guessing plugs are $10 each. Might be worth it to pay and extra $100 or do for my mechanic to do it. Guessing I need to have it towed too.
Old Dec 17, 2020 | 11:28 AM
jssjr5591's Avatar
Now after researching and talking to my friend I bought car from, it could be an EGR valve problem. Either clogged or a vacuum problem.
Evo2nv
May 23, 2017 07:51 PM
jsamaniu
Jun 14, 2016 02:08 PM
Pr0x1mo
Aug 3, 2014 12:24 PM
MagnumVP
Apr 22, 2009 11:02 PM
signtist2004
Oct 19, 2006 11:01 AM
