dash lights
Old Sep 26, 2009 | 03:41 AM
snowman32's Avatar
Exclamation dash lights
hi im need help with my lights, ive a 94 lancer and the passenger rear tail light has stopped working have checked fuse under bonnet and it keeps blowing also the dash lights dont work and all lights around the instrument panel also have checked bulbs not them,ive just replaced da stereo and have 3 spare wires ,and the front right turn signal has stopped working tried the bulb also,but no luck can anyone help.cheers in advance.ps its a diesel 2.0 non turbo fun but economical.
Old Sep 28, 2009 | 01:57 PM
black rider's Avatar
Default dash lights
Seems as though these critters have electrical gremlins galore. First i would disconnect the negative battery cable and do the basic remove and replace of all the fuses, pull the relays and test them with an ohmeter and replace as needed.
Replace cables to battery (positive first THEN negative) take your ohmeter or test light and connect the negative to the negative terminal on the battery and put the positive test lead into the radiator fluid, careful not to touch the sides of the radiator. If you get a reading more than 00.4 you have a hot wire touching the chassis somewhere. You say you just installed a new radio? Check and double check all connections, ground the amplifier to the chassis directly, ground the speakers also, check your power lead to the radio for improper grounding. And finally check your positive lead from the battery to the PCM and starter for corrosion or loose connections.
One more thing, most vehicles have a dimmer switch for the instrument cluster check and replace if necessary if none of the above addreses the problem you may have to replace the light switch, stalk, turn signal unit on the left side of the steering column.
Monte98
Dec 8, 2010 01:46 AM
claytonkobe
Sep 19, 2010 12:28 PM
Scott01Sport
Nov 14, 2005 11:18 PM
Ricsta
Feb 12, 2005 10:11 AM
Ripley
Dec 19, 2004 04:39 PM
