Diamante won't start
Old Dec 27, 2005 | 01:57 PM
smccant1's Avatar
Default Diamante won't start
I recently purchase a japanese replacement engine for my 1995 Diamante LS DOHC that only has about 45,000 mls. I installed the new engine, replaced timing belts and switched manifold, bought brand new plugs and wires. The new engine spins but won't crank. I've also tried switching the sensors but it's still won't start. Need Help?
Old Dec 27, 2005 | 02:16 PM
Patrick's Avatar
Administrator
Default RE: Diamante won't start
is it the EXACT same engine? what was wrong with the stock engine? did the new engine come with a new eCU?
Old Dec 30, 2005 | 07:54 PM
jssmith6's Avatar
smccant1,
My condolences. I had something very similar to your delima several years back. I'd replaced the timing belt on a V6 Mitsubishi engine and she wouldn't start. I had reassembled her with the cam shafts one notch out of time. This is easy enough to check without removing the timing belt cover. Simple have someone turn her over while you've got your hand over the air intake. If you don't feel as strong a vacuum as should be there, the cams/crank may be slightly off; just enough that she won't start.
Do you have fire?
If so, have you tried ether in the air intake? What happened?
Good luck
mysticrythms
Mar 19, 2014 08:17 PM
mnerin
Dec 24, 2013 04:30 PM
mnerin
Dec 8, 2013 10:58 AM
defender321
Apr 14, 2012 10:17 AM
Croatia84
Mar 7, 2011 02:22 PM
