Eclipse A/C Question
Old Oct 31, 2006 | 10:09 AM
durango's Avatar
Default Eclipse A/C Question
Ok, since we've figured out that the motor in my '96 RS has been changed to a '98 Neon motor, would it be likely that the A/C Compressor be from a Neon as well? It's my understanding that some parts will interchange between the two. The A/C Compressor quit working about 2 months ago. Since it was so close to the winter, I didn't want to spend the extra money having it fixed. Any knowledge is appreciated. Thanks.
Old Oct 31, 2006 | 02:31 PM
Default RE: Eclipse A/C Question
If it quit working it might just be from a neon
Old Nov 1, 2006 | 10:53 AM
durango's Avatar
It worked fine for from the day I bought the car. (July '05) Sometime in August '06 it started making a squeaking noise. It sounded as if it locked up. I turned the A/C off. I stopped the car and opened the hood to see what was going on. As I opened the hood I could smell burning rubber. I turned on the A/C for just a minute to see what was happening. Immediately it started to squeal. I then turned the A/C off, and drove the rest of the way home without A/C. (Sucked too!!) How do I determine if this compressor is the Eclipse compressor or the Neon??
I'm sorry if I seem dense when it comes to cars. I've never really had an interest in messing with them until now. Now if you'd like to put a Honda TRX 250R two stroke motor in front of me, that's different.
Old Sep 28, 2007 | 04:53 AM
glen5122's Avatar
from what u said the compressor is definetly gone dont worry bout finding witch motor it from it needs replacing if you want ac
GSXEX Knubbe
May 18, 2007 07:57 AM
TheEngineer
Feb 18, 2006 11:03 AM
