Eclipse Not starting
Old Jul 15, 2006 | 12:37 AM
1.8Underdog's Avatar
Default Eclipse Not starting
I bought the 94 eclipse 1.8liter and it diddnt start and the people didnt want to mess with it, there is no spark coming out of the wires, you can smell gas but wo'nt start, would it be the coil not getting electric to the plugs? I'm sure it needs new plugs cause it has been flooded i'm geussing and new wires to boot but does it sound like a coil?
Old Jul 15, 2006 | 12:46 AM
magnet's Avatar
Default RE: Eclipse Not starting
sounds like it possibly. There are ways to check a coil with a ohm/volmeter. I suggest you buy a haynes or Chilton manual and give it a go and post the results back here. good luck
Old Jul 15, 2006 | 09:08 AM
Check the output from the coil. check your plugs and wires are all good.
Old Jul 15, 2006 | 04:23 PM
ok i will do that probably mondy thanks, hope fully its nothing bad,
chazspeedy69
May 22, 2014 02:18 PM
Blazejben
May 14, 2012 03:59 AM
monkeybumburning
Sep 18, 2006 12:59 AM
bekahu410
Aug 20, 2005 12:34 AM
Nubian QT
Oct 9, 2003 12:09 PM
