Eclipse problems after tune-up
Old Nov 1, 2007 | 08:39 AM
pnballdoc1's Avatar
Default Eclipse problems after tune-up
Hi Everyone,
New member here. Already have found alot of good info here. Wondering if someone could help me. Gave my Wife's 01 3.0L Eclipse Spyder a tune-up yesterday - denso plugs, cap/rotor, wires, and K&N drop in filter. When I started it up it was/is running rough and threw a cel before I hit the end of the block. It's blowing white smoke and I can smell gas at the tailpipe. No power when I accelerate. The local Autozone is over an hour away on a round trip and I'm wondering if I could drive it that far to get the code(s) read without totally screwing up the car? Any ideas would be appreciated. Almost wished I left it alone, but the stuff I replaced was badly worn.
Thanks,
Pnballdoc1
Old Nov 1, 2007 | 11:26 AM
Default RE: Eclipse problems after tune-up
Make sure you hooked up the air sensor correctly, check all the connections are tight and there are no air leaks.
Then reset the ECU by removing the negative battery terminal for about a min, andturn the key in the ignition while the battery is dissconnected just to drain any extra power.
Old Nov 1, 2007 | 01:09 PM
dsm1990gsx's Avatar
ORIGINAL: Sebba
Pretty much what he said, make sure u didnt crack any plugs when u installed them and check to see if you possibly crossed plug wires?
Old Nov 1, 2007 | 02:09 PM
If you crossed any, the car wouldnt start
Old Nov 1, 2007 | 02:58 PM
pnballdoc1's Avatar
Well, I'm an idiot. It's amazing. The car still starts and runs even if you have #3 & #5 crossed at the cap. DOH! Had to take the plenum off again to figure that out.Cars running fine now. Thanks everyone for your help.
Pnballdoc1
Old Nov 1, 2007 | 03:08 PM
oooh you have the V6 duuh. That makes sence why it would run : )
Old Nov 1, 2007 | 03:12 PM
dsm1990gsx's Avatar
ORIGINAL: pnballdoc1
Pnballdoc1
Well at least you found out what was wrong and fixed it. I bet you'll never do that again lol.
Unsullied_Spy
Jun 6, 2012 05:02 PM
jp2000
Jan 1, 2012 05:21 PM
RazorG
Mar 5, 2011 11:58 PM
RazorG
Feb 27, 2011 11:42 PM
98eclipsers
Jan 31, 2006 01:08 PM
