Electric fan fuse is popping
Old Mar 30, 2006 | 12:38 PM
edgeofsane's Avatar
Default Electric fan fuse is popping
Just curious if there was anything I could do to prevent this from happening? Buy a new fan maybe?
Old Mar 30, 2006 | 09:31 PM
ACWiz's Avatar
Default RE: Electric fan fuse is popping
It would be a good idea to test the draw that the fan has. It's no use in replacing it if it's working properly. You are blowing a fuse because there is a greater draw than what the fuse is rated for. That could be because of corroded connections, shorts or a a bad motor. I would suggest having the motor tested first.
Hope this helps!
redcentinela
May 21, 2011 11:56 AM
Obakemono
Jan 31, 2010 07:11 PM
Vaggelis
Aug 25, 2008 08:54 PM
Maximus99
Mar 7, 2008 11:09 PM
StRyKheR
Mar 16, 2006 03:34 PM
