fault code p0155 o2 sensor
Old Aug 17, 2005 | 08:22 PM
3000gtyeah's Avatar
Default fault code p0155 o2 sensor
hi my name is john and i have a 97 mitsubishi 3000gt with a 3.0L engine with a sohc non turbo. my check engine light came on not to long ago and it said code p0155 witch is a oxygen sensor . i replaced the oxygen sensor and erased the code and everything was fine ,but when i turned the car off and then crank it back up the check engine light comes back on with the same code . i replaced the oxygen sensor before the catylitic converter was that the right one? because i know theres 2 more 1 for each manifold. please help!!!!!!
thanks
Jonathan
softarno
Jan 2, 2015 08:38 PM
ghia61
Jun 5, 2013 11:50 AM
montero1
27
Dec 3, 2012 10:44 PM
dpeek5
Nov 4, 2012 06:51 PM
3000gt123
Sep 22, 2006 04:45 PM
