FRUSTRATED ALREADY
Old Mar 10, 2007 | 04:32 PM
mirageEvo99's Avatar
Default FRUSTRATED ALREADY
I need to change my brakes and I am having a lot of trouble removing the caliper. I have smothered the bolts with WD-40 and they will not budge. Which way do I have to turn them so they can come off??
Old Mar 10, 2007 | 05:07 PM
Default RE: FRUSTRATED ALREADY
your un-screwing them from the back so looking at the rotor you have to turn clockwise. What i needed to do it, because mine were kinda rusted too, was get a large socket wrench (around 1-1.5' in length) cuz that gives you more torque. It really can be a pain in the ***. You are turning the wheel also right? Cuz turning the wheel will give you alot more access to the area. Then just give it hell. If you still have some trouble the spray it down with some PBblaster. That will loosen up the rust. Good luck
BTW are you changing the pads or the rotors, cuz if its just the pads you dont even need to take the whole caliper off. There are 2 different sets of screws. One set screws in the parts that whole the pad in place. And the main bolts that hold the caliper in place
Old Mar 10, 2007 | 06:24 PM
Yeah, all I am changing are the pads. Its a mitsubishi mirage 1999.
Old Mar 10, 2007 | 06:42 PM
00GalantMan's Avatar
use a cheater bar.
Old Mar 10, 2007 | 11:42 PM
Thanks man
yinglingj
Mar 11, 2014 05:12 PM
nick_200321
Jan 28, 2008 10:02 PM
nick_200321
1st Generation
Sep 23, 2007 03:19 PM
brknhrtdpimp1489
May 19, 2007 10:00 AM
kornkid1215
Jul 18, 2006 07:50 PM
