Fuse Keeps blowing
Old Jun 23, 2013 | 12:20 PM
cnrcpla's Avatar
Default Fuse Keeps blowing
Car is an 02 lancer OZ rally. I went through a car wash yesterday with an undercarriage clean. On the way home, the engine just stopped. A small 20amp fuse that goes to the ECU blew. So I replaced the fuse and drove home. Today, it just wouldn't stay running. After replacing the fuse 5 times to get home, I ran out. After picking up more fuses, simply flicking the key on would pop the fuse. So, in order to drive it, I need to disconnect the battery. This keeps it from popping right as soon as the key is flicked. Now with it running and the battery reconnected, if I hit a big enough bump, the engine just shuts off. Then I have to repeat the process. Also, when the car start back up, it shoots up to 4-5k RPMs then goes to normal. The battery is reading 12.5 amps with the engine off, and about 14.2 with it on. It's the number 8 fuse in the box that keeps blowing. Anyone have any suggestions? Thanks in advance. I've checked all the visible wires for fray or corrosion, so I have no idea where to go next.
Old Jun 23, 2013 | 04:28 PM
Akzle's Avatar
you have a ground short on that circuit. Find it before you destroy something expensive.
Old Jun 23, 2013 | 05:10 PM
cnrcpla's Avatar
Alright, bit of an update. It stalls out when ever I hit a big enough bump.
How can I find the short? I've tried looking at all the wires I can find, I just can't seem to find any frayed, broken, or corroded wires Come to find out the radio has a not so well done wiring job,so I'm going to rewire that legit and see of that might help. Other than that, I've honestly checked every other wire.
stp135
May 27, 2022 09:50 PM
litildevil75
May 2, 2016 07:25 AM
pomerjon
Jan 19, 2010 01:49 AM
The Bassist.
Aug 31, 2009 10:08 PM
BlackGalant
Apr 24, 2009 07:40 PM
