having a spark issue on 97 eclipse.
Old Jul 1, 2005 | 05:53 PM
whteclipse's Avatar
Default having a spark issue on 97 eclipse.
I can here my ignition shorting out. It sounds like its coming from The coil. Do these go bad often? If so how much are they to change?
Old Jul 2, 2005 | 10:02 AM
pc's Avatar
pc
Default RE: having a spark issue on 97 eclipse.
If you can hear it but performance seems to be ok maybe you just have a loose connection? I would check all the high voltage connections, plug wires, coil wires. If there is some shorting going on that externally grounds the high voltage side I would run the car in complete darkness to see if you can observe any arching. Use a flashlight to then identify the location. I would not think a bad coil would just give off a sound without any voltage problems.
NI7S2S0AN
Mar 16, 2011 01:58 AM
heads up
Nov 1, 2010 11:40 AM
EclipseGuy92
Jun 2, 2010 04:14 PM
lamboeclipse
Nov 15, 2006 01:44 PM
shamsulaswad
Oct 31, 2004 07:44 PM
