Heater core Removal question
Old Feb 13, 2015 | 11:34 PM
doolman's Avatar
Default Heater core Removal question
I plan to do the front heater core remove/install 2002 Montero limited. Is it necessary to discharge the AC and disconnect the lines into the housing? Or is it possible to remove the
core without disturbing the AC?
Old Feb 14, 2015 | 05:58 PM
2001Mitch3.5XS's Avatar
I believe that you will have to discharge and reclaim the Refrigerant in order to get the housing out of the area to work on it. Let us know how you make out...
Old Feb 14, 2015 | 08:39 PM
doolman's Avatar
Default Thanks
Thanks Mitch,
Some vehicle manuals tell you to disconnect AC lines at housing. I was hoping after removing the dash etc. I could remove the core from the housing without taking out the housing. Today I bypassed the heater core so I could drive it until I get a couple of days to work on it.
H
Old Feb 15, 2015 | 06:25 AM
That is a great idea as this would take a few days to do, Are you sure there is a problem with the heater core.. Leaking, Blocked etc...
BigDASH
Jan 15, 2009 08:32 AM
theburna
Oct 7, 2007 06:03 PM
gdwife1836
Aug 7, 2006 12:28 AM
jhny7
Jan 3, 2006 01:36 AM
bcolins
May 23, 2005 09:50 AM
