HELP with Profec B-Spec II
Old Mar 18, 2005 | 04:16 PM
congonator's Avatar
Default HELP with Profec B-Spec II
I need help tuning my spec II, i just got it and was wondering if anyone has any tips or anything to help me tune it or if anyone lives around the NRH/HEB area so we can meet up and tune on the go....Also if anyone has any presset setting that i can just put in to get me by for now that would be great!!! Thanks
Old Mar 18, 2005 | 05:56 PM
DSMTalonAWD51's Avatar
Default RE: HELP with Profec B-Spec II
what do you mean help tuning it? the profec b is just a boost controller you set it at the level you want there isnt any tuning involved
Old Mar 18, 2005 | 06:28 PM
congonator's Avatar
See, its more difficult than that!!! There are alot more features than just a boost controller because i dont understand all of the components...so it is not just a boost controller, its a little more difficult....I just need help
Old Mar 20, 2005 | 12:13 AM
GReddyGST's Avatar
Ive got the same boost controller; setting it depends on if you stil have the stock turbo, and/or other performance. The first thing i did was change the measurements to p.s.i instead of KPa. Then adjusting your Lo boost setting to a gain of 20, gain %; 25%, and set your warning to about 16 lb's. You can jack it up to w/e the hell amount you want, but a) your internals will get screwed up if you put it too high, b) itll just spike at w/e you set it too, and it will go down to most likely somewhere around 10-12 l.b's
antox18
Aug 27, 2007 07:16 PM
Gstfat
Jun 20, 2007 07:55 AM
Gstfat
Jun 18, 2007 06:35 AM
roccu
Apr 19, 2007 07:36 PM
Hamx0r
Nov 9, 2006 07:35 PM
