Helpp
Old Jul 21, 2010 | 01:37 PM
p0301 help needed's Avatar
Default Helpp
My engine light came on listing p0301 as the issue cylinder 1 misfire.
SO far i have : replaced the plugs wires and gaskets.
didnt work .. engine light came on with same erroe a few days later
ran fuel cleaner and replaced the fuel filter and the battery
came on again
had throttle plate and throttle core cleaned.
came on again.
not sure what to try next.
seems to run ok.. a little jerky when i get up over 60mph. BUT im at wits end!!
Old Jul 21, 2010 | 04:40 PM
byrdman's Avatar
u can tell alot form the spark plug. the cylinder that is calling for the misfire, take that spark plug out and see if it looks white and ashy, or black and burnt, or clean.
if it white and ashy then ur lean
if its black and burnt the ur rich
if it is clean (like it is new) then u r not getting fuel.
i bet it is an injector
Old Jul 21, 2010 | 04:44 PM
byrdman's Avatar
the way i check injectors is switch the injector to a different cylinder, clear the code, start it and see if it is calling the same code but on a different cylinder.
Old Jul 21, 2010 | 06:18 PM
well i replaced the spark plugs on the first go around about 2 weeks ago. so i am hoping they still look new
Old Jul 21, 2010 | 06:19 PM
maybe ignition coil???
Old Jul 21, 2010 | 08:16 PM
dsm1990gsx's Avatar
Try a compression test. Rule that out first and go from there.
Old Jul 22, 2010 | 10:12 PM
MitsMaster's Avatar
What year and model is the car?
Old Jul 27, 2010 | 08:53 AM
lol sorry its a 2002 montero sport 3.0
Old Jul 27, 2010 | 08:56 AM
what will the compression test show? Im just wondering what part cud be needed??
Old Jul 27, 2010 | 12:53 PM
dsm1990gsx's Avatar
It'll tell you what condition that cylinder is in.
95-3000gt
Aug 8, 2012 12:26 PM
p0301 help needed
Jul 21, 2010 01:32 PM
deyluvziggy
Jun 24, 2010 02:26 PM
jtherrien69
Feb 16, 2009 05:48 PM
himynameiseric
Oct 16, 2008 09:50 PM
