Higher Octane?
Old Apr 26, 2007 | 02:29 AM
TMR Net Shark's Avatar
Default Higher Octane?
Generally stating in any car, can I use 91 octane in a car that says to use 87? I know if you do the reverse you get knocking or pinging. Will using a higher than recommended octane hurt my engine at all? Or will it actually help it?
Cars in question:
2007 Toyota Camry
2008 Mitsubishi Lancer GTS
1998 Ford Explorer XLT
Old Apr 26, 2007 | 09:56 AM
Default RE: Higher Octane?
nope, shouldnt hurt it at all
Old Apr 26, 2007 | 02:31 PM
Dusty Eclipse's Avatar
I couldnt see why it would hurt it either... but for some reason whenever I used it in my Civic that called for87(Yes, the Civic I wrecked.) it tripped the CEL.
Old Apr 26, 2007 | 08:05 PM
Manybrews's Avatar
using higher than recommended or needed octane CAN cause problems, as well as **** away money.
do NOT use it unless called for.
period.
Old Apr 27, 2007 | 06:05 AM
silvercoupe97's Avatar
Makes sense to me.
Old Apr 27, 2007 | 10:54 AM
...explains a lot.
Old May 11, 2007 | 12:32 AM
year1lazer's Avatar
all higher octane does burn faster i tried it on my tiburon V6 i lost mpg.plus it cost more.your car will run better on 87 oct unless you have a car that needs 91 oct
Old May 11, 2007 | 02:05 AM
Higher octane doesn't burn faster, it burns slower, that's why turbo cars and high compression cars use it. It's to keep knock in check AKA pre-ignition.
Octane is NOT a measure of power but of the fuels’ resistance to ignition from heat. A higher-octane fuel, under identical combustion chamber conditions, will burn slower.
http://www.bajajusa.com/High%20Octane.htm
You lost milage because your car spit out unburnt fuel out the tail pipe.
Old May 16, 2007 | 12:20 AM
Clipse1's Avatar
I think year1lazeris right! I tryed it too and I got the same results
Old May 16, 2007 | 12:56 AM
Kaede.Noir's Avatar
ORIGINAL: Clipse1
but it has been proven by silver......
