Higher Octane?
Generally stating in any car, can I use 91 octane in a car that says to use 87? I know if you do the reverse you get knocking or pinging. Will using a higher than recommended octane hurt my engine at all? Or will it actually help it?
Cars in question:
2007 Toyota Camry
2008 Mitsubishi Lancer GTS
1998 Ford Explorer XLT
Cars in question:
2007 Toyota Camry
Higher octane doesn't burn faster, it burns slower, that's why turbo cars and high compression cars use it. It's to keep knock in check AKA pre-ignition.
http://www.bajajusa.com/High%20Octane.htm
You lost milage because your car spit out unburnt fuel out the tail pipe.
Octane is NOT a measure of power but of the fuels’ resistance to ignition from heat. A higher-octane fuel, under identical combustion chamber conditions, will burn slower.
