IAC Diagnosis help
Old Jan 19, 2014 | 08:38 AM
mantis270's Avatar
Default IAC Diagnosis help
Working on an 03 Monty Sport, 3.0L, 2wd... just put then engine back in. Had it out to replace gaskets and rings. Got it back in and hooked up and after running for a bit and about 10 miles into the test drive, The check engine light comes on... got a code P0507 ...
I checked the IAC with a multimeter and got readings between pins 1 and 2 of 45 ohms... This is above the range of 28-33 that I've read. Can this cause the idle to be too high..?
Old Jan 22, 2014 | 12:51 AM
mxmikie's Avatar
yes......p0507.....Idle Air Control System RPM Higher Than Expected
mxmikie's Avatar
it can also blow the ECU
fireman53d
Feb 7, 2014 08:01 AM
katsat
11
Jan 19, 2009 03:30 PM
martin2jam
Oct 17, 2007 08:44 PM
misko
Sep 25, 2005 03:12 PM
pc
Jul 16, 2005 07:15 PM
