IAT code
Old May 18, 2005 | 12:10 PM
michael49's Avatar
Default IAT code
Have a 1992 eclipse 1.8 Keep getting a intake air temp code, checked the sensor out and it appears to be in line with what the book says it should be. The resistance goes down as the intake air goes up. Any ideas? The car seems a little sluggish
Old May 18, 2005 | 12:52 PM
pc's Avatar
pc
Default RE: IAT code
Can you verify that the sensor is getting the proper voltage?
Old May 18, 2005 | 01:35 PM
michael49's Avatar
PC,
Would I take a reading from the line-side of the plug that connects to the air filter box? If so what pins do I need? Would this cause a sluggish acceleration?
Old May 18, 2005 | 02:30 PM
pc's Avatar
pc
To measure input voltage you would need to know which pin was the input voltage. I think? you could use your multimeter(MM) to ground to test either pin to see which is the line voltage and which is the return signal voltage. You would also need to know what the proper line voltage was supposed to be. I had assumed from your 1st post that you knew what the values were. The IAT may be changing (R) but it may not be changing it correctly. If the intake air temp is not being measured properly you could get a lean/rich mixture which could account for the running problems. Are you also getting an Oxy Sensor code? If the mixture is wrong the Oxy sensor may also tell you. I once had a code that said TPS problem. I tested the TPS according to the factory manual, it checked ok so I looked elsewhere for a long time. I finally just replaced the TPS and the problem was instantly corrected.
mnkydik420
Nov 1, 2006 05:12 AM
rainerhpv
Apr 4, 2006 01:10 PM
96green_machine
Mar 5, 2006 07:18 PM
91montero
Sep 14, 2005 07:17 PM
davebarr33
Jul 28, 2005 11:29 AM
