If your good, I need HELP BADLY
Old Feb 20, 2006 | 03:57 PM
NESpeed's Avatar
Default RE: If your good, I need HELP BADLY
Sounds like your going to have to, like what slow420a mentioned.....go threw the entire harness to find the short, thats the only thing I can think of, with it being so intermittent. Sometimes with age the wires insulation becomes very brittle and starts to come off and show bare wire, which could be shorting out your system. I hate electrical problems, you might have to find a expert on this matter if you cant find any bad wires....sorry I couldn't help much, good luck.
Old Feb 20, 2006 | 04:27 PM
rustyg's Avatar
Yeh thats about what i have been thinking, thanks for all the help
Old Feb 20, 2006 | 06:19 PM
wait if he has voltage at the coil but it gets not spark still wounldnt that be enough to think the problem is between the coil\wire and plug? and not the ECU or harness wireing?
Old Feb 20, 2006 | 07:52 PM
NESpeed's Avatar
ORIGINAL: EMonz57
No because the cam sensor tells the computer where ever thing is at the time, then the computer takes that and tells the coil when and where to put spark. So if he has voltage at the coil then that is tell you that it is a problem with the communication.
Old Feb 20, 2006 | 09:31 PM
ORIGINAL: NESpeed
ORIGINAL: EMonz57
Ahhh I see.
Old Feb 21, 2006 | 11:10 AM
rustyg's Avatar
DAYUMMM...looking forward to doing this...lol
seriously guys, where do i start? Any certain colore wires that make the communication between ecu and coil? Must be certain ones that tell it when and what to fire, any clue what colors they are?
Thanks
Old Feb 21, 2006 | 12:17 PM
Go and get a Haynes Manual. They are only like $20 at autozone. That will have the complete wiring diagram for your car.
Old Feb 21, 2006 | 06:56 PM
NESpeed's Avatar
You may have to go as far as to get a dealer manual. But just start small and simple, start at the cam sensor and coil packs and go from there.
Old Feb 23, 2006 | 08:25 AM
rustyg's Avatar
ok problem solved. It wasnt any one single wire but the whole middle plug isnt seating in tight.
We tested everything yesterday then we were about to quit when we tried it once more, moved the ecu and boom, all four were firing...as it idled if i touched the middle plug on the ecu it would only run on 2 cylinders. Apparently these connections are very sensitive, I need to find away now to make sure this plug seats in there right and this doesnt happen again.
Thanks for all your time and help guys
Rus
Old Mar 29, 2006 | 07:02 PM
TransAmist's Avatar
I don't know if this has already been covered, but just because you buy a new part doesn't mean its good off of the shelf. If there was a harness short, neither of the coils would be working at all ever. And you would have a blown fusible link. Hope this helps if you haven't fingered it out already.
ITSMAXWELL
Aug 30, 2009 08:45 PM
jdoggy
Oct 14, 2008 06:31 PM
lhausi2
Jan 17, 2008 06:56 PM
3stan
Dec 6, 2007 11:32 PM
unisoul
Sep 3, 2004 04:37 PM
