ignition coil problem
Old Apr 5, 2006 | 09:48 AM
copperboard's Avatar
Default ignition coil problem
I have 2000 eclipse RS and I have continues ignition coil problem. My engine is loosing its power during the acceleration and shifting. I am getting error cone misfire on Cylinder 4. I have swapped the coils and the problem was following the bad coil. (I got the error cod for different cylinder). So I have replaced the coil, but in few days the problem came back and the coil in same location got bad. First couple days after I have installed the coil the engine drives fine, but then I have the problem comes back and I have problem to determine what is causing to get the coil bad/// any help?
Old Apr 17, 2006 | 11:04 PM
sheleefam's Avatar
Default RE: ignition coil problem
did you ever find the problem
davidsdlck
Dec 22, 2020 06:51 PM
allallyouyou
Feb 12, 2012 11:13 PM
cesargc
Jan 28, 2012 06:05 PM
copperboard
Apr 5, 2006 10:23 AM
visionstudios
Sep 29, 2005 02:02 AM
