IT'S JUST F'ED UP! I NEED HELP
Old May 4, 2008 | 05:25 PM
DCN2TWEEK's Avatar
Default IT'S JUST F'ED UP! I NEED HELP
ok its a 1998 eclipse GS this is what it does it will run fine then start bogging out like its not getting the fuel it need (not the fuel filter already changed it). then sometimes it wont rev. past 4ooo rpm and it idles at 500-600 rpms not normal it usually idles at 950-1000 it guzzles gas like a mo fo when it does this little help please if you have any questions ask me!
Old May 5, 2008 | 06:12 AM
Default RE: IT'S JUST F'ED UP! I NEED HELP
Could be a couple things. Maybe a bad MAP sensor. An air leak possibly at the intake manifold. Thats all i can think of right now
Old May 5, 2008 | 02:36 PM
I am betting on plugs or wires. Change that **** up
Old May 5, 2008 | 06:55 PM
DCN2TWEEK's Avatar
ok thanks
Old May 8, 2008 | 09:35 AM
evo8mrrip's Avatar
any codes?
Old May 8, 2008 | 03:55 PM
EMC 3000GT's Avatar
Plugs and wires.
Old May 10, 2008 | 02:52 PM
laserdriver90's Avatar
mine did that, i have a 1g, mine was plugs, they had water in the bottom of the holes, that or your wire casing is damaged,and they are grounding out to the block, check your MAF plug too, mine boggs out if its not plugged in.... it could also be the coil pack, im not sure though
Lady Grey
Nov 6, 2010 03:35 PM
MadMike1953
Oct 19, 2009 10:17 AM
Gstfat
Sep 11, 2006 04:34 PM
Troy
Jun 27, 2006 02:48 PM
t4_gsx
Aug 29, 2005 02:13 AM
