LED fog, low and high beams won't turn on.
Old Sep 5, 2021 | 10:05 PM
Mgrupac's Avatar
Default LED fog, low and high beams won't turn on.
My 2020 mitsubishi outlander sport had a dead battery after sitting for 4 days. I installed an aftermarket amp and put the remote on wire to the fuse box which is a fuse to the radio. That had to drain the battery since the radio fuse is with the alarm. Jumped the battery and it started right up. Then the LED fog, low and high beams won't turn on. Switch is on. Dash light shows they are on. Fuses are good. Parking and turn signals work. Is there something I need to reset?
Old Apr 8, 2025 | 09:50 AM
petterinok's Avatar
If your LED lights aren’t working at all, the bulbs themselves may be the issue. Although LEDs tend to have a long lifespan, they can still burn out or fail.
Old Apr 25, 2025 | 02:51 PM
arnoliderik's Avatar
There may be a problem with the electronics. The best answer will be given by an auto electrician
ajay62
Jan 29, 2019 09:47 AM
jimmyrinse
Nov 18, 2015 01:11 PM
quechon
Jul 31, 2014 09:31 AM
vladguan
Oct 17, 2012 08:28 PM
star
Jul 26, 2007 04:22 AM
