Mirage 98 - Automatic transmission oil change question
Hi,
I am new to the forum and would like to thank the community for having it, it is a great tool.
Now for the question. I want to change the automatic transmission oil and filter, and I want to double check a few things before doing it (I have mostly worked on cars with manual transmission).
The Chilton seems useless on that one. From what I see, the differential is drained/refilled by draining/refilling the transmission. Also, it seems there is a plug to drain the oil on the bottom right side of the pan. Correct? ALso, does anyone have advice on changing the external ATF filter?
Thanks for your time, and forgive spelling/grammar mistakes, English is not my native language.
E.
E.
newoutlanderfan
08-29-2010 06:17 PM
05, 2000, 98, automatic, change, filter, fluid, gallant, install, mirage, mitisubishi, mitsubishi, oil, trans, transmission
