MMCS Data Files - Japanese to English
Yep - do it _ i'm in NZ and can get you back up and running - but doubt you will have any issues - except maybe what's mentioned above.
You still have the old files that were around in the old days - lol.
It's Windows CE. Linux is just the boot disk and util to unlock the HDD.
a
Is it compatible to do this to J3 also?
aaaaannnnnden
J-01 eng
https://mega.co.nz/#!HJFlCCia!yKWQzR...7j0lvNyk-wGZyo
Remove HDD from MMCS
Remove battery for minimum 10 minutes
Connect to IDE of PC (MMCS drive only)
Boot from CD XBOXHDM
Choose option 3 ‘boot linux with locking\unlocking utilities.
Wait for Root@Xbox-HDM:/1 Prompt
Type command
unlockhd –p <KEY>
this is the J-01 Key I used
B2BAB3BCB0DFACBEB1BBBEDFB1ADD2CDC9CEB5B2DFB19E8996 DFAA8C9A8DDFDF
If completed successfully typing command fdisk –l will show the partitions
Turn off pc
Run Windows with MMCS HDD connected
Locate Loading.kwi on partition with folder screendata.
Backup the original loading.kwi then replace with the new one
Reinstall HDD into car
Reconnect battery
Nek munnut….. English J-01
J-01 eng
Type command
unlockhd –p <KEY>
Turn off pc
Reconnect battery
Hello all. Wondering if this is still a valid procedure or has someone discovered a new way?
Originally Posted by W@zfa
J-01 eng
[url
J-01 eng
[url
https://mega.co.nz/#!HJFlCCia!yKWQzRHk1Zdvvr5jvYXDM4ZWypiCx7j0lvNyk-wGZyo[/url]
Type command
unlockhd –p <KEY>
Turn off pc
Reconnect battery
Type command
unlockhd –p <KEY>
Turn off pc
Reconnect battery
Sophie Hemmington
Dec 6, 2023 12:06 AM
backwards
Sep 18, 2014 02:05 AM
