OD problem
Old Oct 22, 2006 | 10:29 PM
mr.shug1135's Avatar
Default OD problem
On a 1990 mitsubishi eclipse gs when od is engaged car will shift into every gear ecept for overdrive. Could this be something simple to fix this problem or I'll need to rebuild or replaced tranmission.
Old Oct 23, 2006 | 08:24 PM
Manybrews's Avatar
Default RE: OD problem
does it not shift from 3rd to 4th? or does it seem to go into nuetral?
Old Oct 23, 2006 | 09:54 PM
yea it seem like it goes into nuetral
Old Oct 24, 2006 | 07:18 PM
Manybrews's Avatar
then you have a failed end clutch assembly.
its not necessary to remove or rebuild the entire trans to repair that problem.
find someone that knows mitsu trannies and have them repair it.
Old Oct 24, 2006 | 09:56 PM
Ok Thanks for the info.
