OIL???
Old Aug 2, 2007 | 03:36 AM
Shaun VanCity GST's Avatar
Default OIL???
Hey all... sorry for this very minor querry but I just got a 97 Eclipse Spyder GST and am wondering what oil to use??? i've heard 5W 50 but i'm not sure. Thanks in advance, Shaun
Old Aug 3, 2007 | 10:17 AM
Default RE: OIL???
i believe most people use 10w-30 for the summer and spring and as it gets colder go to a 5w-30. Please someone correct me if this is wrong. And i like to use synthetic only
Old Aug 10, 2007 | 07:02 AM
QueenCaroline's Avatar
Default RE: OIL???
Yeah, 10w30 is a little heavier, and that's what you want in the summer when temps are high and oil can thin out a little too much. Then in the winter, when EVERYTHING thickens up (manual trans oil, engine oil, etc.,) you want to run a little thinner, hence 5w30.
And I am also a strong supporter of synthetic motor oil! Mobil 1 user myself. I no longer use any conventional oil (except on the lawnmower). Only problem is that on some older vehicles, changing over to a synthetic oil when conventional oil was previously used can uncover some "leaks". Molecules in conventional oil are not of uniform shape. Think of geometric shapes such as cones, spheres, columns, and so on, all jumbled up together. The molecules in synthetic oil, however, are more uniform in shape, such as mostly spheres, and they all "fit" together better. They can also slip into tiny cracks and breaches in gasket surfaces better, sometimes leading to (very) small leaks. Not really a problem, it just makes some people think that they did something wrong by switching over. And it doesn't always cause a leak. It's usually at most an oil pan that gets a little soaked.
Off on a tangent, I know. It's a stress reliever for me, whatdoyawant!
Old Aug 30, 2007 | 11:56 AM
Default RE: OIL???
queen C - thanks for your most enlightening and detailed response. I am going to get some synthetic 10w30 right now... thanks a lot. Shaun
Old Aug 30, 2007 | 12:53 PM
jason clipse's Avatar
Default RE: OIL???
royal purple is the shizzle i use it on my car its expensive but its nice and use a purolator pure one filter it comes in a silver box and the filter itself is blue
ccernst
Jan 14, 2011 08:38 AM
Vadimus
Nov 26, 2010 12:13 PM
TheRock0720
Nov 12, 2010 12:30 PM
lancer0594
Feb 5, 2009 06:48 AM
hairbear65
Feb 1, 2009 09:35 AM
