Overheating
Old Jun 18, 2008 | 03:49 PM
surfacewarriorjc's Avatar
Default Overheating
I have a 1997 mitsubishi eclipse gst and just recently my temp gauge has been steadily rising after about the first 5min of drive time...my ac also gets very hot... when i come to a stop it seems to go down slightly... I have checked and refilled the coolant with no results... I am not very car savy soI really dont know what all to try... also have a fuel pressure solinoid malfunction, I have no idea what, where or how to fix it, asked auto zone and they said they have never heard of one... any help would be much appreciated...
Thanks,
Josh
Old Jun 18, 2008 | 03:54 PM
PoolhallJunkie777's Avatar
Default RE: Overheating
first of all, dont run your car too much to the point of overheating. it sounds like your thermastat went out on your car. go back to autozone or what have you, and get one for your car. it should be pretty easy to replace. also if your ac is hot, recharge it.
Old Jun 18, 2008 | 06:50 PM
dsm1990gsx's Avatar
Start w/ the thermostat it the cheapest and easiest thing to do.
Old Jun 24, 2008 | 11:59 PM
jerusry's Avatar
your fuel pressure solenoid is by your brake fluid reservoir if i am not mistaken. its just a wee bit too late to head out to check on the car. if you still have your vacuum diagram on the bottom of your hood. it should show you which solenoid it is... i will check tomorrow. and try to get a pic loaded.. even though i suck at loading pictures.
also, make sure your fans are turning on....
Old Sep 9, 2008 | 07:02 PM
importorigins's Avatar
Were you ever able to get this problem figured?
EclipseGirl98
Jun 4, 2005 07:29 PM
crackhead365
May 24, 2004 10:56 AM
dirk
May 1, 2004 02:43 PM
Spyderman9803
Apr 20, 2004 02:17 PM
mastermechanix
Apr 17, 2004 03:52 AM
