P/S pump pulley
Old Dec 20, 2007 | 07:37 PM
djailer's Avatar
Default P/S pump pulley
I need a new pulley for my p/s pump. Not the pump, just the pulley. Even the dealer can't/won't sell it separately. Wrecking yards won't part it out either. Now what???
I emailed A1Cardone on the off chance they will sell me one. What a b***ch![:@] Any chance anyone has a pump from a 97 GST ( or close enough...)and can just part with the pulley?
Thanks
Old Dec 20, 2007 | 08:19 PM
dsm1990gsx's Avatar
Default RE: P/S pump pulley
Why do u need the pulley? You probably cant get it seperatly b/c it probably a press fit.
Old Dec 21, 2007 | 11:50 AM
djailer's Avatar
Mine is bolted on. 19mm nut with lockwasher. I took it off. The pulley looks like it is out of true - you can see it wobble when the engine is running. The pump shaft doesn't look bent so I am hoping replacing that pulley solves the screeching belt problem. I've only had the car for about 8 weeks now and it didn't squeak for the first four or five.
I even contacted a place that specializes in supercharger pulley conversions. Only $300 for them to make me one They say they might be able to fix mine - I have to take it in to have them look at it. I may end up just getting the whole p/s pump from a junkyard!!!!! But I was hoping against hope I could find the pulley somewhere. Someone somewhere had to make the one which is on there now.
MNalfa
17
May 9, 2019 06:07 AM
Dookitchen
May 31, 2006 10:12 PM
newspeed
Nov 25, 2005 04:44 PM
ecp_drv
May 18, 2004 12:42 AM
03eclipseGT
Oct 6, 2003 08:43 PM
