Passenger headlight not working
Old Sep 13, 2009 | 07:26 PM
mattyblast's Avatar
Question Passenger headlight not working
...and it's not the bulb. Any suggestions? ('09 Eclipse Spyder)
Old Sep 14, 2009 | 07:22 AM
GS Man's Avatar
What it could be is the wires powering it. Check for power and ground. I'm sure there are plenty of diagrams on the internet to help you out with that. Also, it could be the connector, might have a buildup of corrosion (seeing as it's an 09 thats hard to believe) at the pins, or the wires might have high resistance, which can be as bad as having an open. I don't think it could be the fuse because the one fuse that's for the headlights, goes to both of them, so they'd both be out if it was the fuse. So check for those three things dude: power and ground, corrosion, and resistance. If you have a DMM/DVOM, this helps a lot! Hope this helped dude.
kostovski.dragan
Jul 30, 2014 04:55 AM
cirroc_boy
Jul 19, 2013 09:17 AM
cirroc_boy
Jul 17, 2013 11:08 AM
2000zeroGT
Dec 19, 2008 10:48 PM
xtremest26
Feb 17, 2006 02:07 AM
