Please help...
Old Apr 27, 2007 | 09:07 PM
Superman750's Avatar
Default Please help...
I got an 03 Eclipse GTS, the code it readsis a cylinder 6 misfire. It started right after putting on a cold air intake. What it does the rpms will jump about 50-100 rpm about once per second. When I am driving and have the throttle pressed down any amount, and have to slam on the brakes, it feels like the vacuum for the brakes is gone. Does anyone have any ideas? Please help! I can answer any questions...
Old May 11, 2007 | 12:49 AM
year1lazer's Avatar
Default RE: Please help...
put it all back to stock disconect you batt first let it reset it self if it still doing it after its all put back to stock make sure you did not splice a wire and check your mass airsencer that you did not pull a wire out
Old May 11, 2007 | 07:31 AM
Check your spark plugs and spark wires
LeoGS
Nov 6, 2020 06:12 AM
enzo_hashmat2006
Oct 10, 2017 05:46 PM
westentertainer
Nov 8, 2014 12:47 PM
lgibson
Mar 12, 2009 07:04 PM
96eclipsedohc
Feb 8, 2007 09:20 PM
