Please please help!!!!!
Old Mar 11, 2009 | 11:59 AM
lgibson's Avatar
Exclamation Please please help!!!!!
I recently bought a 90 eclipse gs 2.0l dohc non turbo that had no spark, the guy said he took it to a shop and they told him it was the crank angle sensor.. so i replaced that still no spark.. all fuses good, coil packs have power, ground and continuity, power transistor tested good for continuity,but still no spark at the coil? was told on alldata to test ecu connector wire 109 and ground for continuity, says continuity should not exist, and it did exist? where the hell is my problem? i dont feel that ripping into the computer is the right thing, i feel its something small, everything test good for power ground and continuity?? Some one please help.
Old Mar 11, 2009 | 05:24 PM
dsm1990gsx's Avatar
Check for an injector pulse and pull the ecu out and inspect the circuit board.
Old Mar 12, 2009 | 02:10 PM
lgibson's Avatar
k so i tried to check for injector pulse today with a voltage meter. it read 5 thousandths of a volt when i turned the car over? bad ecu?
Old Mar 12, 2009 | 07:04 PM
dsm1990gsx's Avatar
The best way is to use a test light, I sent you a pm w/ my email address. Send me pics of the ecu.
LeoGS
Nov 6, 2020 06:12 AM
enzo_hashmat2006
Oct 10, 2017 05:46 PM
thomas4g63
Nov 28, 2008 12:52 PM
91 eclipse gs
1st Generation
Sep 26, 2007 07:03 AM
96eclipsedohc
Feb 8, 2007 09:20 PM
