problem with Ralliart 2007 - check engine light
Old Aug 12, 2013 | 11:39 AM
Mauricio Alan's Avatar
Default problem with Ralliart 2007 - check engine light
Hello and good morning
since 1 year ago, that I have my car, a 2007 ralliart. I've been experiencing a random issue with the car.
It can pass several months without the issue appearing. and when it happens it happens 1 or 2 times and then it doesnt shows for a couple of months.
The issue is Im driving normally, either driving automatic or shiftronic, and then when Im accelerating, the car looses power, stays in 2 cylinders and the only way to get rid of this is to turn the car complete off and start it again and then the check engine lights goes off and the problem dissapears.
so far we have changed the following parts
- spark plug cables
- crank position sensor
- Camshaft position sensor
- spark plugs
when the car has the issue, we plug an ODBii reader and it doesnt shows anything on it.
anyone can point on the right direction or has any ideas ??
thanks
Mauricio A.
Old Aug 12, 2013 | 02:46 PM
Akzle's Avatar
i'm assuming you mean 2 /second gear, rather than 2 cylinders?
auto gearboxes are horrible. horrible.
g'box solenoid, torque converter, random electrical problem, computer, blown fuses, maybe it just doesn't like you?, find some gravel roads and take if for a thrash every now and then.
Old Aug 12, 2013 | 04:40 PM
nope ..... I mean 2 cylinders......
thats what we notice the last time it was at the repair shop.
2 cylinders still working and 2 cylinders are not working
it I turn off the car and turn it back again it works fine, and the check engine light goes off and also the problem
the complete details are
Im driving normally, when Im accelerating all the way. the car looses power, and stays in 2 cylinders (the check engine light goes on). it doesnt turn off or anything. it just looses power, a couple of times when the problem happened I went to the repair shop and the mechanic told me that 2 cylinders are not running, we turn the car off and then turn it back on and it works fine
Old Aug 13, 2013 | 02:37 PM
Akzle's Avatar
sounds like an ignition module fault. check coils, plugs, leads, crank sensors... basically, your ignition system.
but first, do a compression test.
Old Aug 14, 2013 | 01:36 PM
bordermec's Avatar
Default No codes
When you use the OBDII tester can you live feed ? To see where the electrical breakdown is? You have a intermittent problem and the right tester can find it. If there is no code what OBDII tester are you using?
jssjr5591
Dec 19, 2013 07:52 AM
scottz123
Apr 3, 2013 04:33 PM
barjer
May 21, 2010 11:38 AM
pgb205
Jun 4, 2009 10:40 PM
Eric B
Mar 2, 2009 12:35 AM
