Problem with rough start 04 eclipse gt
Old Mar 3, 2012 | 11:49 PM
hypno89's Avatar
Default Problem with rough start 04 eclipse gt
Sometimes when I start the car the idle jumps up and down than almost stalls than goes to normal drives normal with no problems.I also notice while this happens I hear a noise from the back of the car sounds like a pump sucking for air or fuel (fuel pump) but if I give it gas it runs fine wouldnt you think if it was the fuel pump it would run horrible all the time not just at start up 1-5 times.
Old Mar 4, 2012 | 01:18 PM
DarkPoet's Avatar
Have you checked your intake?
Old Mar 4, 2012 | 07:40 PM
hypno89's Avatar
check what on it ? the car runs perfect after the initial start.Ive replaced the cat behind the engine after the manifold and both o2's up.New air filter and tune up to come once I figure out this issue.
Ericschmits
Apr 28, 2015 11:37 PM
Jesse24
Aug 19, 2014 08:35 AM
Dustin Imler
Nov 27, 2012 03:44 PM
Silver00GT
Sep 24, 2007 08:11 PM
naruto454
May 24, 2007 05:22 PM
